How can I recover data from damaged hard deive
My external hard drive fall down on the solid surface. Now when I am connecting the drive, light is bli king and keep loading but its not showing my files
No swapping enclosures here; the USB port is on the PCB :-(. Since you dropped it the issue is likely a headstack alignment error. STOP USING THE DRIVE, IT WON'T HELP!
You will most likely have to replace the headstack. This is NOT a DIY job; the part must match as closely as possible to the original drive. And yes, WD and Seatrash DO USE parts that are just different enough to be rejected due to marginal differences; it's based on parts availability in the factory. You might be able to do this yourself if you can find a donor drive from the same production time and lot but you need a cleanroom, many tools to protect the donor headstack (touch=death to the donor headstack) and a tool like the PC-3000 to work around the head differential issues to make the drive accept it if it's not a very lucky match.
このアンサーは役に立ちましたか?
Same here I dropped mine and it lights up but the reader arms are not moving, question is, are the reader arms specific to this model (2TB) or can I use another drive and simply swap over the guts to it? (2TB WD Blue WD20NMVW)
過去 24時間: 0
過去 7 日: 5
過去 30 日: 25
今までの合計 560
