メインコンテンツにスキップ
The Xiaomi Redmi 9A is a low-budget smartphone by Xiaomi released June 2020. It has a 6.53" IPS LCD display, a 13 MP main camera, a 5000 mAh battery, and runs on a Helio G25.
43回答 すべてを表示
Sering restart sendiri terus masuk ke main menu Terus berulang kali
Pas sudah di main menu hp langsung mulia nyala pas mau ke layar wallpaper ada lingkaran terus ke restart kembali begitu terus
Google translate:
It often restarts itself and then goes to the main menu over and over again
When you go to the main menu, the cellphone immediately turns on, when you want to go to the wallpaper screen, there is a circle and then it restarts again and so on
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @tgrzann
Try the following:
Wipe the cache partition and check if the phone works OK
Here's the procedure:
Turn off your phone if it is on and then press the Power button and the Volume Up button (both together) to boot into the Recovery menu.
When the Recovery menu appears release the buttons.
Next use the Volume Up and/or the Volume Down button to move through the menu options and highlight Wipe Cache Partition, then press the Power button to select it
Confirm by selecting Yes and then wait for the cache to be cleared.
Once it has finished select Reboot system now to restart the phone.
DO NOT select wipe data /factory restore as this will erase all your data and downloaded apps and will reset the phone back to its factory default condition. It will be like when you first got it.
Google translate:
Coba yang berikut ini:
Hapus partisi cache dan periksa apakah ponsel berfungsi dengan baik
Berikut prosedurnya:
Matikan ponsel Anda jika dalam keadaan hidup lalu tekan tombol Daya dan tombol Volume Naik (keduanya bersamaan) untuk boot ke menu Pemulihan.
Saat menu Pemulihan muncul, lepaskan tombol.
Selanjutnya gunakan tombol Volume Naik dan/atau Volume Turun untuk menelusuri opsi menu dan menyorot Wipe Cache Partition, lalu tekan tombol Daya untuk memilihnya
Konfirmasikan dengan memilih Ya lalu tunggu hingga cache dibersihkan.
Setelah selesai pilih Reboot system now untuk me-restart telepon.
JANGAN pilih wipe data / factory recovery karena ini akan menghapus semua data dan aplikasi yang Anda unduh dan akan mengatur ulang ponsel kembali ke kondisi default pabrik. Ini akan seperti saat Anda pertama kali mendapatkannya.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Tgr Zann さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 81
