メインコンテンツにスキップ
Spilled water on the computer and the screen is dim.
Hi,
I spilled water on my computer and dried it. Everything now works well except that the screen is dim, I have to use a flashlight to see what's on the screen. However, when I connect it to a monitor it displays everything on the monitor. What could be the problem?
How can I fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@lesetja54561 possibly a blown backlight fuse, blown backlight WLED driver, shortened out display adapter etc. Time to take it apart and check for corrosion as well as shorts. Everything will be a guess for now, We will need to know the exact number of your motherboard. The information should be printed on the top side of the board. Anyhow, open it up and take some really good pictures of what you see. Post those with your Question so we can see what you see and hopefully get your computer back to its former glory :-) iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lesetja さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 14
