Green line down the center of screen
I replaced the battery, and now I have a green line down the center of the screen. Right down the middle. I'm hoping it's just the connector not seated correctly. Has anyone else seen this before?
Some people have reported this this happens when rubbing alcohol gets into some of the connections. Try waiting around an hour and see if the issue resolved.
I’ll try to find the link to the specific question where this was found, but won’t be able to at the moment due to being on mobile.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 108
4 件のコメント
Did you use the isopropyl alcohol to clean the adhesive off the display and battery?
Jacob Mehnert さんによる
I didn't need to on the screen side. It all came off surprisingly easily. I did use it on the battery side and needed to put some under the battery as the pull tabs broke off.
mary さんによる
@mdrumhel but you did use some? Some users have reported this happening with Rubbing Alcohol.
Jacob Mehnert さんによる
I did use some. That's interesting. Has anyone reported fixing it without needing to completely replace the screen?
mary さんによる
