メインコンテンツにスキップ
北米で2010年3月に発売されたニンテンドー DSiの大型版モデルです。ほとんどの修理作業はドライバー一本と開口ツールのみで完了できます。
157回答 すべてを表示
Help Finding DSi XL Lower Screen Backlight Fuse
I was making a DSi XL Macro mod. It worked for a little bit, but it just randomly quit. It blinks blue for a second, and dies. The bottom screen didn't blink like I'd expect if the 330Ω resister failed. Ive tried known good lower screens on this, Which leads me to believe its the lower backlight fuse, However, I cant find where the fuse is. Does anyone know where it is?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
The DSi has 2 fuses, both labelled F1 for some reason. The first one is near the charging port
and the second is on the underside of the power board.
I think the one you're looking for would be the one on the power board, but I'll let you determine that for sure. Good luck!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Unfortunately, those fuses are unrelated. Those fuses are power related (charge fuse and battery fuse respectively) I need to find the fuse or component related to the lower screen backlight.
さんによる
@soup244 Well, those two are the only fuses in the console, so something else must have failed. Unfortunately, I don't know what it might be
さんによる
コメントを追加
回答を追加する
Soup さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 16
今までの合計 54
