メインコンテンツにスキップ
The Dell Chromebook 11 3189 is the first model of the Dell Chromebook line of laptop computers introduced in January 2014.
6回答 すべてを表示
upgrade in ssd hard
can we upgrade the storage of dell 3189 chrome book by replacing ssd hard
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
@aqeelraza For the specific model you have listed, the storage is soldered eMMC. There is no way to upgrade the storage. If you need to expand storage for files which are not accessed often eg videos and documents, you can buy an SD card and leave it in the inbuilt reader on the laptop. This will basically function like a USB flash drive that is permanently attached to the system. This workaround is not recommended for use with applications as an SD card will be much slower than onboard storage and will slow down the application noticeably.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
can i replace the emmc chip for a higher capacity one?
--written on a kali linux dell 3189 with 7gb of storage left
さんによる
コメントを追加
回答を追加する
aqeel raza さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 18
今までの合計 618
