メインコンテンツにスキップ
A2115 / 2020 / Processors from 3.1 GHz 6-core i5, 最大3.8 GHz 8-core i7. 発売日は2020年8月4日。
45回答 すべてを表示
Fan turns on but screen wont boot
I was using my mac when the screen glitched and random colored pixels in square pattern appeared and then the computer crash and rebooted just for it to happen again
Now it wont boot up and the only sign of activity is the fan reving every other minute
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hello there,
I had the the same issue with older iMac. The issue was a faulty graphic card. I replaced mine with working second hand and got it working perfectly fine. I am not sure if the case will be the same with you but it is some direction point. If you have some friend with the same model to slap the cards just to test and confirm if this is the problem.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi thank you for the reply i dont really know how to replace the graphics card for the imac so it seems like ill have to bring it into the store
Thanks alot
さんによる
コメントを追加
回答を追加する
yaboi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 37
