Opening of a WM-b39
Hi,
Does anyone know how to open a Sony WM-B39 or have a manual as I struggling to find one online.
thanks
この質問は役に立ちましたか?
Hi,
thanks
この質問は役に立ちましたか?
このアンサーは役に立ちましたか?
Thanks for this. Have you opened one before? I’m struggling a little with the first part as when you insert the driver and move the tab to the left it only releases one hinge of the cassette holder does the other side just pull out? Thanks again
I haven't worked on that model but normally all you are doing is releasing the catch (lug?) that holds the case together. Once released you can gently pull,pry the case apart.
In the manual it shows in which direction to move it.
過去 24時間: 2
過去 7 日: 6
過去 30 日: 26
今までの合計 90
1件のコメント
Hi, I am trying to teplace the capstan belt of my Sony B39 walkman. This is a quite complex one. Does any one have any experience on this topic?
Serge Gouders さんによる
