My phone battery draining so fast
I have to charge 90-100% twice a day
I am also not using havy task, only YouTube, WhatsApp, and google photo
Hi @subhamroy
The battery may be failing and needs to be replaced.
Here's a video that shows what to do.
Search online for BN4A battery to find battery suppliers that suit you best.
このアンサーは役に立ちましたか?
Well I will suggest you to read this article : https://wethegeek.com/android-battery-dr...
And I will also suggest you to use a good phone cleaner app as well because some time apps running in the background can also be one of the main reason.
このアンサーは役に立ちましたか?
My suggestion phone battery backup was one year warranty year war so replace your battery every year
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 16
過去 30 日: 42
今までの合計 2,497
8 件のコメント
My battery is about to die.
Manmohan Murari さんによる
50% battry last less than hour and problem on charging.
Ayush さんによる
@ayush64525
See the MOST Helpful Answer below.
jayeff さんによる
My phone is better drain problem 😭 please solve now sir
Redmi note 7 pro さんによる
@redminote749774
See the Most Helpful Answer below.
jayeff さんによる
3件以上のコメントを表示
