メインコンテンツにスキップ
The Rock Band Fender Stratocaster Wired Guitar is a guitar-shaped controller for the Rock Band video game franchise for Xbox 360.
2回答 すべてを表示
Rock band 1 wired guitar will not turn on / connect.
I have a Xbox 360 wired Rockband 1 fender, it’s been 5ish years sense I last used it but I dug it out to play clone hero on, but when I plugged it wasn’t working, the light for the Xbox 360 logo on it would flash for a second and then shut off. I first tried a different break away cable end but I got the same result, I tried the classic wiggle the cable around to see if holding the cable in a specific way would make a better connection but I had no luck with that. I took the guitar apart and looked at the main board and there were these 2 capacitors that’s caps had turned a purplish black, all the other ones still had silver caps so I’m guessing that may be the problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
I have the exact same problem let me know if you solve it please and thank you
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Did you fix it yet?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sleepless Gamer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 47
今までの合計 432
