メインコンテンツにスキップ
The Samsung Galaxy Tab A 10.1 is known by different models depending on the features. Regular model: SM-T580 (WiFi), SM-T585 (3G,4G/LTE and WiFi) released in May 2016 or S-Pen model: SM-P580 (WiFi), SM-P585 (3G,4G/LTE and WiFi) released in September 2016. It is a 10.1- inch tablet manufactured by Samsung Electronics and their new high-end “A” series.
108回答 すべてを表示
Touch screen not working after attempting screen replacement.
Hello, I’m in the final stage of replacing my Tab A 10.1 screen and powered it on after connecting the ribbons and before gluing down the glass to ensure everything checks out ok. The tablet powered on, however the screen appears magnified and the touchscreen function doesn’t work. I checked that all the ribbons are snapped in place and haven’t glued it back together. I tried a hard shut off twice and removed any film from the screen and that didn’t fix the issue. I didn’t have the problem prior to changing the screen. I replaced it because the screen was cracked. Please advise what I did wrong.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Did you buy just the replacement glass or the whole frame assembly which includes a new digitizer? You mentioned gluing it back together, which you only do when replacing the glass itself. I repaired an 8" tablet a few weeks ago using this kit from ebay - https://www.ebay.com/itm/353195276454 - as you see all you need do with this is transfer the battery and circuit boards over. Maybe that would be an option for you still? Also I always try to find a YouTube video and follow along, even though I've done many phones etc, there's always that one little step I've overlooked!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I purchased the replacement glass from Amazon Screen Replacement for Samsung... https://www.amazon.com/dp/B08TJ29VGP?ref... and followed this YouTube video https://youtu.be/w6DE8IoGqkU?si=ZXY6YN4c... Other than my broken screen, the tablet was work properly prior to the glass replacement.
さんによる
コメントを追加
回答を追加する
Justme さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 42
今までの合計 256
