メインコンテンツにスキップ
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
170回答 すべてを表示
I don t have display on my monitor
Hello i don t have display on my monitor and i tried to change RAM and it's not working. I tried whit HDMI and VGA it's still not working.I tried RAM and video card on another pc and RAM worked and video card didn't, after I got another older video card and I tried and I still have no image.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@cristiandaniel you did not tell us anything about the computer. at least let us know what make and model your motherboard is . Also, let us know if you tried the monitor on another computer to make sure that it is working. You already know that there is at least a partially fault with your video card "video card didn't". You mentioned that you tried HDMI and VGA as well, are those outputs from your video card or from your motherboard. If your monitor works on another computer or if you tried a known-working monitor on your computer, then the issue will be the video card.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Cristian Daniel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 8
