メインコンテンツにスキップ
The Xiaomi Poco M3 is a budget smartphone which was released in November, 2020 and is equipped with a big 6000 mAh battery block, a tripple main camera and a 6.53 inch IPS LCD.
No signal error is coming
No signal not going phone call give me this solution
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
コメントを追加
4件の回答
最も参考になった回答
I have this problem and after looking for awnsers i cant find something that repairs this problem and i changed some network ic (i dont know what they call it) and my problem solved but before doing that restart your phone and check. Remove and reinsert the SIM card and check. Switch between different network modes and control. Check with any other SIM card working, and that your SIM card or your network operator may be having problems and after that you need to bring your phone to repairers to check.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Not showing sim can you resolve that
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Some cellphones often experience similar damage, especially the Poco M3, signal damage often occurs, the first step is to try reloading your cellphone, if it's still the same, try checking the baseband, on most Poco M3s the signal is lost because the baseband is also not there, if the baseband is still there there is, but the signal is still not lost, there is an indication that there is damage to the signal IC, if the baseband is lost, it means there is an indication of damage to the CPU IC, (usually the baseband loses the cellular signal and the WiFi doesn't work)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lokothamnaik390 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 41
今までの合計 1,197
