メインコンテンツにスキップ
My screen is not displaying
When I switched on my laptop everything comes correct but the screen is not displaying, I have change the screen but still the same thing but when u connect with tv it displays on the screen of the tv and works perfect. What could be wrong with the machine
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@stephenopoku when you changed the LCD display, you made sure that the new one is a good, working one and is the exact same model? Turn the computer on and make sure that it starts up. In a darkened room, use a flashlight and shine the beam at an angle against the screen. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. Since this is a new display, it would be either the backlight driver or the backlight fuse as well as the display connector. We would need to see your connector as well as your motherboard. At least we would need to know what make and model your motherboard is.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Stephen Opoku さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 92
