メインコンテンツにスキップ
9月20日にAppleが2019年に販売したiPhoneは5.8インチのOLED、3つのカメラがつき、バッテリー駆動時間が大幅に増加しました。iPhone XSの後継機です。
150回答 すべてを表示
Cornice schermo scollata / detached screen bezel
Per togliere lo schermo si è scollata la cornice metallica che lo tiene al telefono. Apparentemente non c'è niente di rotto ma lo schermo non si accende più, avete suggerimenti? Grazie.
To remove the screen, the metal frame that holds it to the phone was unglued. Apparently there is nothing broken but the screen does not turn on anymore, do you have any suggestions? Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
I wouldn't think that removing the frame would cause the screen to fail, but along the bottom of the screen are delicate electronic circuits that I'm guessing the frame was protecting. I suspect that in the process of separating the frame from the screen, some of those circuits got damaged. About all you can do at this point is replace the screen and hope that's the problem.
Of course you checked the connectors carefully with a magnifying glass and a bright light for any bent or broken pins, correct? And looked at the flex cable for any tears or damage? Wouldn't hurt to clean both sides of all the connectors with 90% or higher concentration isopropyl (rubbing) alcohol and recheck.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks for your reply, the phone works fine with a new screen. But I'd like to recover the original. I don't see any circuitry under the bezel though. I thought it could be a silver glue weld that holds the frame glued to the screen, on the right side that has come unstuck. I ordered the specific glue, as soon as it arrives I will try. Thanks for collaboration.
さんによる
コメントを追加
回答を追加する
olleto49 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 59
