Laptop does not turn on
The laptop does not turn on when the power adapter is connected to the laptop its led goes off
the battery might need replacement. tried a different power adapter?
このアンサーは役に立ちましたか?
My laptop battery problem is from long time. But so long my laptop is running without battery but now it is not running
Hello @nii99203 , does it power on with the battery disconnected? If so, you may need a replacement battery. Also, as @carlotremolada said, it may be worth trying another power adapter to make sure!
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 172
