メインコンテンツにスキップ
The newest generation of the EliteBook 840 model. The EliteBook 840 G5 is a business-oriented laptop manufactured by HP in 2018.
22回答 すべてを表示
Why my laptop only start when I charge externally or some time interna
When I start my laptop I can't start but after some try I start after 3 or 4 min It automatically switch off sometimes it start when I charge externally but same switch of problem
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi @ixlucifer
Seems like the battery is failing and needs to be replaced.
Does the laptop turn on and stay on if the charger is left connected?
If the laptop stays on, create a battery report to check the status of the battery.
Once you have the report, compare the Design Capacity value versus the Full Charge Capacity value. For a good battery they should nearly be the same.
You can work out the battery status as a percentage by using the formula Full Charge Capacity value x 100 ÷ Design Capacity value.
If the battery needs replacing search online for 933321-855 to find suppliers that suit you best.
Here's the HP EliteBook 840 G5 Battery Replacement guide that may help.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
IX LUCIFER さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 43
