メインコンテンツにスキップ
Televisions made by the Chinese multinational electronics company, TCL.
265回答 すべてを表示
Why does my television occasionally flicker for a split second?
My television occasionally flickers/cuts to black for a split second. This occurs on streaming apps and gaming consoles. TCL Model 55S555, I’ve been sent two separate models from support and have had the issue with all of them.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@caseymendoza so are these new TV’s? It will all depend on how long the flickering lasts and how often. If you have the exact same issue with two different devices my suspicion are the connections. You always want to start with a new HDMI cable. Next you need to make sure your AC outlet is properly grounded etc. The black screen is usually loss of power/signal.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
These are new TV’s. Issue occurs within a couple hours of having them plugged in. I may rule out the HDMI because the issue occurs on streaming apps that are via the Roku OS. Could be the outlet isn’t properly grounded though. I’ll grab a tester from work tomorrow.
さんによる
Flickering only lasts about a split second and occurs randomly like once every 30 minutes or so.
さんによる
コメントを追加
回答を追加する
Casey Mendoza さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 7
今までの合計 70
