メインコンテンツにスキップ
Find repair and further information about the Maytag MFI2568AE* refrigerator, a bottom freezer model equipped with an ice dispenser, automatic defrost system, and an anti-sweat heater switch. This page covers information for model numbers matching the pattern MFI2568AE*.
3回答 すべてを表示
no light on front controls and the lights out in the refrigaroter
have done everthing you have said the refrigaroter is still working just no light on front controls and the lights out in the refrigaroter is it the front control board are main control board model number is mfi2568aes Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @larrychilcutt
Just clarifying if the display still works on the control panel?
If it does try entering the service test mode as described on p.4 and then perform service tests #151, #152 & #153 as described on p.5 and check what happens.
If it doesn't then most likely the problem is on the main board as that is where all the relays that are operated/released to turn on lights etc are situated and also where the power is distributed from - see the schematic on p.1
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Larry Chilcutt さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 36
