メインコンテンツにスキップ
2021年10月発売。モデルナンバー GB7N6(非5G mmWave)、G9S9B(5G mmWave)。
50回答 すべてを表示
Temporary connecting PIxel 7 display to Pixel 6?
My Pixel 6 display is dead. I wonder if it is possible to connect Pixel 7 display temporarily?
I don't care about display size as I only need it for a temporary use - just want to configure debugging.
I've seen a similar question regarding Pixel 7 pro, but there were no an answer.
==== UPDATE
There is a hope that display connectors for Pixel 6 and Pixel 7 are the same. Attaching the image created from images used in display repair manuals here.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Unfortunately, chances are that either the connectors or the pinouts are different, you might have to get a cheap cracked display just to test with, if you can find one online on sites like ebay. @digitalair
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Added image in the Question update
さんによる
@digitalair Ah ok then you have a bit more of a hope, i've tried to find a pinout for the pixel 6 display connector but unfortunately came up empty, the best advice i can give is to try it and find out, worst case scenario it could kill the display or the board, though.
さんによる
コメントを追加
回答を追加する
Digital Air さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 12
今までの合計 41
