メインコンテンツにスキップ
Repair information for nebulizers, medical devices responsible for the administration of drugs to the lungs.
1回答 すべてを表示
Whenever I connect the pipe to nebulizer the machine slow down.
When i connect the pipe to nebulizer the machine slow down after removing the pipe the machine run faster. Though i have cleaned and check the pipe nd even the nozzle but unale to sort the problem.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@hrushikesh86167 that is to be expected. Once you connect the nebulizer the pressure needed to nebulize the medication is what is placing extra torque requirements on the machine. IT is not a matter of how much work your machine performs, the only thing that matters is how well it nebulizes the medication.
Of course, you always want to make sure that the container that holds the med as well as the nebulizer/mask as cleaned and replaced as per manufacturer.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Hrushikesh Sonawale さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 92
