メインコンテンツにスキップ
The Whirlpool WRS588FIHW is a 28 cu. ft. side-by-side refrigerator with a 17.6 cu. ft. refrigerator and a 10.4 cu. ft. freezer, featuring an EveryDropTM Water Filter dispenser, ice maker, smooth door style, and adjustable gallon door bins. Its dimensions are 36" W x 69 3/4" H x 36 1/4" D.
1回答 すべてを表示
Why won’t my ice maker fill up with water to make ice?
We have had 3 repair technicians out to fix our ice maker. The ice maker slowly started to make less and less ice then it just stopped. We have figured out that the ice maker is not filling up with water. Now we do have a water dispenser also and it is working just fine. It is just the ice maker. Please help! We just got this refrigerator two years ago.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @brandiegoddard
You never mentioned what the repair technicians did (or didn't do) to fix the problem?
Here's the tech sheet for the refrigerator that may help.
Enter the service diagnostic mode as described by the sheet and step to Test #45 Icemaker Water Fill test and check the results.
The dispenser and ice maker valves are a twin valve unit (example only to show image of valves unit)
It may be that the ice maker inlet valve is faulty or clogged up.
WPW10341320 - Whirlpool Refrigerator Water Inlet Valveの画像
製品
$117.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Brandie Goddard さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 63
