メインコンテンツにスキップ
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
170回答 すべてを表示
Why is one of my headphone mic working and the other not
So with the headsets on the back I/O one of the headsets mics don’t work but with the one where it doesn’t work when put in my phone it works completely fine just that on my pc it decides to output the game audio but bass boosted which is weird why it does that if it works completely fine on my phone i assume it’s some kind of software issue
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi @platinumchest
Check in Control panel > Sound > Playback > Properties to make sure that the correct audio output is selected.
The same with Control Panel > Sound > Recording to make sure that the microphone (check in Properties on that tab) has been selected etc.
To get there type Control Panel in the search box on the Taskbar and select Sound.
このアンサーは役に立ちましたか?
スコア 1
12 件のコメント:
Hi yes that was one of the first things I did I have it on the right microphone and speaker
さんによる
Audio does come in but it’s just muffled I have the input volume at the max
さんによる
I can’t hear my voice when I talk all I hear are the taps I do to it
さんによる
So I tried some things the buzzing of the mic is back when I play a game I can hear usually the game through the headphone and random sounds that keep repeating
さんによる
@platinumchest
Check in Device Manager > Sound, video and game controllers > right click on Realtek High Definition Audio > Properties > Details > In Properties box select Hardware IDs > and note the ven dev and and subsys info in the value box.
It might look something like ven 10EC dev 0887 subsys10438445.
Whatever it is, search online using the string of numbers e.g. ven 10ec 0887 10438445 as similar to my example and check what model Realtek device it is and if there are drivers for it. You may have the incorrect drivers.
Just something to check.
さんによる
7件以上のコメントを表示
コメントを追加
Yeah it’s all software, try reinstalling the drivers and check again to see if it works
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Yeah I’ve searched it online people have Realtek high definition audio driver but mine just says high definition audio driver
さんによる
So once I did that there no more buzzing but I there is still no output
さんによる
コメントを追加
回答を追加する
Platinum Chest さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 59
