メインコンテンツにスキップ
Laptop screen blacked and caps lock kept being blink
Hey. My laptop is 4 years old. Last day while watching a YouTube video it get stuck and audio also got stuck and shut down. After that the screen is blacked when ever I try to open it. And the caps lock kept blinking. It blinks like 5 times in same manner and another 3 times in faster manner, then repeat. Is there any solution to solve it.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi @illumi12476
Unfortunately, if your model is a HP Pavilion 15t-dk100 then there's no separate RTC coin cell battery on the motherboard, like there is for the laptop mentioned in the link above, as the RTC voltage is supplied by the main battery.
The BIOS reset procedure is basically the same though
i). Switch off the laptop and disconnect the charger from the laptop if connected.
ii). Disassemble the laptop and disconnect the battery from the systemboard.
Here’s the maintenance and service guide for the laptop, taken from this webpage. Go to p.35 to view the procedure to remove the battery. You don’t have to completely remove the battery, simply disconnect the battery cable from the board.
iii). Press and hold the laptop’s Power on button for a full 30 seconds and then release it. This will restore the BIOS to its default settings, in case a corrupted BIOS was the cause of the problem.
iv). Reconnect the main battery, re-assemble the laptop, connect the charger and turn on the laptop and check.
If it starts OK there may be a message about the date and time being incorrect. This is normal as the BIOS has been reset. Once the D&T have been adjusted, the message won’t appear the next time the laptop is started.
If the error code is still there, then commiserations, as there is a problem on the systemboard. You may either have to find the schematics for the systemboard and try to work out what’s wrong or contact a reputable, professional laptop repair service.
このアンサーは役に立ちましたか?
スコア 1
12 件のコメント:
Thanks brother. I will notify after doing it.
さんによる
My laptop is pavilion 15-dk0045tx. Sorry I just noticed the number now. Can I apply the same procedure.
さんによる
@illumi12476
Yes.
It uses the same maintenance and service guide as linked above.
さんによる
Thanks dude...
さんによる
Hey, the steps didn't work for me. I handed it to a reputed service centre near me. They worked it for about 3 weeks. They said they replaced several components and also replaced the chipset. Now the display turns on but after a few minutes it turns off. They said they can't identify the problem with it and they will return my laptop next day. Is there something else I can do other than board replacement. I was just watching a video while my laptop shuts down. I wish I could know the reason why it became like this.
さんによる
7件以上のコメントを表示
コメントを追加
回答を追加する
illumi さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 21
今までの合計 199
