A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
Is it sufficient to handle all the power requirements for the motherboard, board powered peripherals etc as well as now the extra water cooling feature e.g. pump if powered internally?
Have you tried different USBs/ports?
Frankie Vaughan さんによる
Unfortunatelly it is not something i can easilly test out because does not happen often. i'll try some ports and then report back.
Thomas de Boer さんによる
No problem!👍
When it crashes, does it blue screen?
Alisha C さんによる
@thomasdeboer
What is the wattage of the PSU?
jayeff さんによる
4件以上のコメントを表示
