メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Casio's scientific calculator released in June 2015. Uses Classwiz technology and is widely used in exams.
Calculator is in 'PAUSE' mode
The calculation was done in VECTOR mode from the menu. When trying to do something, the calculator hangs, after clearing by the 'ON' button, you can see this status of MENU. Apart from these 3 modes, no other mode is showing, if I want to scroll up or down, the pause sign (2nd picture) is coming on the upper right side.
⁉️ How to get back all mods like before?
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
4件の回答
最も参考になった回答
Here’s a quick fix for your calculator:
  1. Press SHIFT + 9, then press 3 to initialize everything.
  2. Next, press SHIFT + 7 + ON. The screen will display "DIAGNOSTIC."
  3. Avoid pressing AC. Instead, press 9.
  4. The screen will fill with 8's. At this point, press SHIFT, then ON.
Your calculator should return to normal! Hope this helps!
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Its work! Thank you for the solution.
さんによる
コメントを追加
According to the manual, page 2, you can initialize (aka reset) the calculator by SHIFT 9 (RESET) 3 (Initialize All) = (Yes)
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Note: this is a duplicate as the answer with the link was marked as spam
さんによる
By the way, @nayemmonir , here you can find the manual
さんによる
コメントを追加
According to the calculator manual (see page 2), you can initialize/reset the calculator by pressing SHIFT 9 (RESET) 3 (INITIALIZE ALL) = (YES)
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
doesn't work this
さんによる
@nayemmonir Have you tried removing the battery as @dannish said?
さんによる
yeah, nothing changes
さんによる
@nayemmonir Ok, anyway that symbol means "The display currently shows an intermediate result of a multi-statement calculation." (page 4 of the manual, can't link due to antispam). Maybe is still waiting for input?
さんによる
コメントを追加
@nayemmonir Have you tried removing the battery for a few minutes? That may reset the calculator to default settings.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I just did but it doesn’t work 🥲
さんによる
It firstly worked but further it shows suddenly and I do the same process flashing doesn't work what to do😕
さんによる
コメントを追加
回答を追加する
Nayem Monir さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 61
今までの合計 1,662
