メインコンテンツにスキップ
The OnePlus 6T is an Android smartphone made by OnePlus. It was announced on October 29, 2018 and released on November 6, 2018.
26回答 すべてを表示
Phone is not dash/fast charging + Windows not recognizing USB device
So i cycled back during the rain. The phone didn't get super wet and continued to function but since then does not charge properly. I can charge via USB cable through my PC as it refuses to dash charge via charging brick and the PC will keep giving me warning USB device not recognized.
I have a pair of cables that i have tried it with - so its not the brick or the cables but something to do with the phone me thinks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I would recommend to fully power off your phone, and let it sit for a few hours for it to dry up. Then, turn it back on and it should work again if nothing is damaged.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
This happened about a week ago. So while I can't recollect if I have given it time, but the phone other than the charging is working correctly. I am just trying to identify if replacing the USB charging port will be the apt solution. Because it is charging just not at the fast charge level and not through the brick
さんによる
@nabeelkhan1082, does it even charge at all?
さんによる
コメントを追加
回答を追加する
Nabeel Khan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 31
