メインコンテンツにスキップ
5 blinks on TV whenever power on attempt
Having an issue with this tv. I'm getting a standby light and when I press the power button it turns green then almost immediately back to standby red and flashes 5 times.
I was tryna follow this and the first thing checks out but I don't understand how to check between the G to panel harness. Is there anything else I should be looking for?
Update (08/04/23)
This is a picture of the TCon board. Let me know if you need any other pics
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
@davidjolly53848 you could check if the voltages that are on pin 8 of the connector are also on the connector on the harness, that corresponds to the same pin. I usually just check for corrosion, bend pins and tears. There is usually not a lot of other things that can go wrong with the harness. T-con board failure on Sony of this model are pretty common. If you want to, you could post a good picture of your T-con board. That way we could try to have you measure a few things to see if your T-con board has the important voltages.
このアンサーは役に立ちましたか?
スコア 1
13 件のコメント:
I got you i'm not in front of the TV but i'll have some pictures for you tomorrow.
さんによる
@davidjolly53848 no problem. We'll be here :-)
さんによる
@oldturkey03
Soot or shadow under CON1 on the tcon board image supplied?
さんによる
I think its a shadow but i can clean the connector with some acetone
さんによる
@davidjolly53848
Acetone is not a good choice as it may damage the plastic of the connector. It can be very aggressive with some types of plastic
Isopropyl alcohol 99%+ is the best. If none available a "barely moist" i.e. not dripping etc, Q-Tip (moistened with clean water) would most probably work just as well
Just be careful not to damage the connector pins and make sure that it is totally dry before powering it on.
さんによる
8件以上のコメントを表示
コメントを追加
回答を追加する
David Jolly さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 106
