メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Repair information for the fall 2018 addition to the ASUS ROG Zephyrus lineup. This is a high-end gaming laptop in the thinnest frame for those specs at the time. Model number: GX531GS-AH76.
Using different edc cable
Hey, so i have zephyrus s gx531gxr. It uses 40 pin edc cable that i have to replace. I have ordered cable from similar model (gx531gx) by mistake, and I am wondering if this cable will work on my device. The main difference is that the gx531gxr has 240hz screen and gx531gx has 144hz.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@filipklaczek for as long as the pitch of the pins is identical it should work. I did not see any crossover etc, so I would definitely give it a try. After all, if it does not work, you will know that you need to get an original.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi @filipklaczek,
If it doesn't work the Asus part number for a GX531GXR EDP cable is 14005-02780800.
Search online using the part number to find suppliers that suit you best.
さんによる
コメントを追加
回答を追加する
filip klaczek さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 123
