メインコンテンツにスキップ
2018年10月26日発売。モデル番号はA1984, A2105, A2106, A2108。オプションとしてGSM もしくは CDMA / eSIM, nano-SIM もしくは dual-SIM / 64, 128もしくは 256 GB /カラーバリエーションはブラック、ホワイト、ブルー、イエロー、コーラル、レッドがあり。(正しい発音は"iPhone 10 R"です)
470回答 すべてを表示
iPhone XR screen touch stops working when clicked into frame.
My phone screen works perfectly when not fitted into the frame but as soon as I fit it into the frame and do the final click at the bottom of the screen, touch stops working. As soon as I pop it out at the bottom of the screen, touch comes back again. Any ideas why? Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@briangardner Have you screwed in the final two screws? I had a bizarre issue with a laptop where it would not start once fully assembled unless the screws were put in. I have no clue why but it worked, maybe something to do with screwed-in components having to make contact with the part behind it.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Hi thanks it yes the two screws have been put in and it’s still not working.
さんによる
Alright, remove the screws and open up the phone again. Unscrew and remove the cover over the flex cable. Turn the phone on, and use your finger to press gently on the flex cable connector where it connects to the motherboard. Please keep all metal objects away from the phone when you do this, because the motherboard is exposed. Does touch stop working when you do that?
さんによる
@dannish
I’ll give that a try later thanks. Thanks for your help.
さんによる
コメントを追加
回答を追加する
Brian Gardner さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 4
過去 30 日: 5
今までの合計 35
