メインコンテンツにスキップ
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
Why is my windows causing BSOD
My windows freezes or crashes to BSOD for every few minutes.The BSOD says Kmode exception not handled.I reinstalled windows 3 to 4 times, but the issue doesnt appear for 2 to 3 days, but after that again same issue appears and it starts to reduce the minutes eventually the computer doesnt even boot into BIOS. I need to reset Cmos amd install new windows.Please help me, I dont its a hardware issue i checked all my hardware.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @luffy40372
Without knowing the motherboard make and model it is difficult to give you the precise answer but check that the latest network drivers applicable to the LAN (and WLAN if applicable) network adapters are installed.
A Kmode exception not handled error is usually caused by outdated network drivers.
Try starting the PC in safe mode with networking and check if the problem occurs. In safe mode only generic Windows drivers are loaded and not hardware specific drivers.
If the problem doesn't happen then it is a driver problem.
Be aware that only Ethernet network works in safe mode and not WiFi. Also the screen will look different as well. This is normal.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
My motherboard is H310M s2 2.0
CPU is Intel core i3 9100f
GPU is Gtx 1050ti
8gb ddr4 ram
1tb hard disk
I disable both my network adapters Lan and wifi still my pc is crashing. Is it related to Vanguard of Valorant??
さんによる
@luffy40372
Disabling the adapters doesn't mean that it is not a driver problem. They are still loaded unless you actually uninstalled the adapters but if you restarted the PC again the drivers would have been installed again.
Try it in safe mode as suggested. You don't need to have internet access to run safe mode. It was only to check if the network adapter drivers were the problem
Have you run a virus scan or malware scan?
Also try an sfc /scannow in a Command window run as administrator just to check if the system files are all OK.
さんによる
I dont think system files are the issue since I reinstalled the windows.I uninstalled the drivers, removed the Lan cable and still the crashing issue continuous. Is this a hardware issue?
さんによる
@luffy40372
Please try starting in safe mode
You've got to isolate whether it is software or hardware.
If it also fails in safe mode then more likely it is hardware.
If it works OK in safe mode, it is software
さんによる
コメントを追加
回答を追加する
Luffy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 82
