メインコンテンツにスキップ
2012年6月発売。Core i7プロセッサ 、Turbo Boost / 最大1 GB DDR5 Video RAM
599回答 すべてを表示
MacBook Pro 2012 not powering on
MacBook Pro 2012 is not booting at all. The charging light is green when connected, however the fans don't spin, there is no chime, and the drive does not spin.
  • Reset of SMC and NVRAM
  • Held power button for 30+ seconds with / without power / battery plugged into logic board
  • Removing all connections from the logic board, and testing each component while trying to turn on
  • The internal components/logic board appear clean and undamaged
  • Check power button cable - all fine
  • No liquid damage / all water spots are untouched
The last thing I could try would be to ensure the board is receiving power with a multimeter, I have one but have no idea where to put the connections for testing.
Any suggestions would be appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I'm not sure if you did this: disconnect the battery and the mag-safe, press and hold the power on button for 15 seconds. Now reconnect the battery then the mag-safe. You should get a spontaneous reboot.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
StuartM さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 27
今までの合計 58
