メインコンテンツにスキップ
How to fix the seventh generation of Honda's compact car.
74回答 すべてを表示
leaks washer fluid and headlight washers are not
Interesting conversation. I think I also have a headlight washer issue. My 2002 civic leaks washer fluid after a certain level and headlight washers are not working. Do you have any idea? @boosterr @oldturkey03
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
@mustafaerdogdu this "leaks washer fluid after a certain level" sounds like a leak on the washer reservoir. You will need to have to check that out. As for the washer not working, if you mean they are not moving etc, check the motor according to this
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It sounds like the reservoir (which is plastic) has a creak and needs to be replaced. If the washers don't work just when the fluid is too low because of the leak, that might be related, so I'd start with the reservoir.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mustafa Erdogdu さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 18
今までの合計 53
