Why is my screen showing distorted images/ colors?
画像の内容を見る:
There are a few reasons why your screen might be showing distorted images or colors. Here are some of the most common reasons:
Here are some things you can try to fix this:
If you have tried all of these things and you are still having problems, you may need to contact a computer repair technician for help.
このアンサーは役に立ちましたか?
This is a SNES not a computer. So not sure that if what you put applies to some degree or not here.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 147
I have tried different power supplies, RF cable and R/W/Y composite cables. No difference. Also cleaned cartridges and pins in the console.
Talonrevenge さんによる
@talonrevenge Have the electrolytic capacitors on this console been replaced?
Andrew S さんによる
@andrewsawesome not that I am aware of.
Talonrevenge さんによる
@talonrevenge Have you cleaned the pins on the video connections or the cartridge connections?
Justin Castle さんによる
@erelectronics yes I have cleaned them.
Talonrevenge さんによる
2件以上のコメントを表示
