メインコンテンツにスキップ
Released in 2004, the Toshiba Satellite A65-S126 features a 15-inch display, a 60 GB hard drive, and DVD/CD-RW drive.
5回答 すべてを表示
Where are the memory slot locations?
I have a Toshiba Satellite a65 - s126 (768 MB of RAM)
Is there another memory slot location besides the one under the cover on the bottom in the middle?
I had a total of 768 MB of RAM... I removed the chip on the bottom, and it says I still have 192 MB of RAM (it even booted into windows). So i figure there is another weird chip somewhere, or it has built in memory (I have never seen built in memory before).
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi @ccfcomputing
According to this supplier the laptop has 256MB of non removable memory and one memory slot catering for up to 1GB x PC2700 memory (supplier example only) for a maximum of 1.25GB memory.
The non removable memory is just memory ICs that you see on removable memory modules except that they're soldered directly onto the motherboard.
There are a few modern laptops where all the memory and the storage drive (eMMC -nand flash memory storage) is soldered to the board so there's no option to increase the amount of memory or storage if you want to, i.e. no removable memory slots at all and storage is soldered to the motherboard as well. Something to check if looking for a new laptop.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
CCF Computing さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 35
