メインコンテンツにスキップ
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
170回答 すべてを表示
AMD stock fan unable to spin on its own.
My AMD stock CPU fan has been having issues starting on its own. Moves a few mm on its own, kind of struggling to start spinning. Really wasn't thinking acted more in panic, opened panel and slight finger push was all it needed. I did check to insure cabling was all properly connected. Advice on how to proceed forward.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@pz781n usually this may happen if the CPU fan is in the wrong mode. In the Bios, there should be an option for 3 pin or PWM for the CPU fan. You can look at the fan connector on the fan cable, if it has 4 pins it needs PWM mode and if it has 3 it needs 3 pin mode.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Okay amd bios I have PWM and DC. I’m switch to PWM since I believe it has 4 pins. It was on auto. I’m shut down for a bit and then restart and see if that does it after few goes.
さんによる
コメントを追加
回答を追加する
PZ781N さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 27
