メインコンテンツにスキップ
The Infinix Hot 10i is an entry level smartphone with a 6.52 screen and a 6000 mAh battery released May, 2021.
37回答 すべてを表示
My screen is glitching after I let it replaced to a local repairman
My phone slip on my phone while I am working with something. Then it faced down . I picked it up then it is white screened. The LCD was broken . I immediately bring it to the local repairman to let it fixed for a day then it came well. After a some weeks to a month , i noticed my phone glitching , sometimes flickering then overheating at the lower part of my phone. The repairman said that due to overheating and falling , my phone becomes like that and he told me to repair the screen again. I am skeptical at first because at the 1st day when I got my phone , it is overheating after 5-10 minutes of usage. What should I do?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
@lorrainegrace it is possible that this comes from the screen. I too would replace it once more. But I would also take a look at the charging port, which is located on the lower part of your phone. Let whoever repairs it for you know, to check that board for loose connections and/or damaged components.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Lorraine Grace さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 86
今までの合計 486
