Replacement parts in the battery section
My battery contacts got corroded can I replace the springs and positive plates for better connections?
Yes you can, sometimes a bit of sandpaper to remove the rust works too if you're unable to replace the whole spring. Alternatively, metal spacers like thin washers or a small coin placed beside the spring before installing the battery can help compress the spring to bypass the rusty portion.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 51
1件のコメント
@terrydulong let's see what this looks like. Post a couple of pictures with your question. That way we can see what you see. iFixitでの質問に画像を追加する方法
oldturkey03 さんによる
