メインコンテンツにスキップ
Appleの2016年ラップトップラインアップの最新モデルは、プロフェッショナルユーザーを対象としています。 15インチ、2880 x 1800 Retinaディスプレイ、クアッドコアIntel Core i7、256 GB / 512 GB / 1 TB / 2TBストレージオプション、16 GB RAM、およびTouch Barを搭載したキーボードです。
MacBook Pro won’t turn on after battery replacement
I just replaced the battery in my MacBook Pro 15” 2016 (using the iFixit replacement battery, tools, and guide) but now it won’t turn on at all. After the replacement, I plugged it in to charge as is instructed. A battery icon popped up on the screen, indicating that it was 76% charged. I then pressed the power button, the screen turned on for a split second and then shut off. Now zero signs of life no matter what I do.
I’ve tried all the recommended fixes that I can find (SMC reset, disconnecting and reconnecting the battery, etc.), and there are no visible signs of damage anywhere. At this point I’m worried that the logic board may have somehow been short circuited, but I’m not sure how that would’ve happened since I was extremely careful with my tools and there no signs of a short while I was working. Unless I scraped the logic board with the bottom case as I was putting it back on?
So I guess my questions are:
Does anyone have any idea what my be causing the computer to be dead?
Is it possible that the logic board was short circuited? What could’ve caused that?
Could this have to do with a faulty battery?
Any ideas for how to get it booted up again?
Thanks in advance for any input!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Have you tried running the machine without the battery connected? That way you can rule out the new battery as a potential cause.
Otherwise it's difficult to know. With battery installation, I would retrace your steps. Make sure all your cables are seated soundly. See if you get power if you disconnect other components (trackpad, touchbar, etc....)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Miranda Mertes さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 172
