loud speaker isn't give clear sound?
i have redmi 8 smartphone whenever i play the music on high volume,the sound is very unpleasant to listen so please tell me how can i change my speaker so that i can fix it on my own.
when you put too much volume to your phone it will create distorted signal as it goes pass to the limit audio level that’s why it does sounds awful try to lower it down if the make it clear then there are no issue with your speaker if it stays the same distorted sounds well that has to be changed but it need a bit of experience to change the loud speaker as it involves a lot of tiny components insides which doesn’t need to be disturb or damage as you could create another issues instead of fixing it…. bring to the professional repair phone store for a proper diagnose and for peace of mind let them fix your phone instead
このアンサーは役に立ちましたか?
過去 24時間: 5
過去 7 日: 28
過去 30 日: 69
今までの合計 1,171
Battery exchange
Suman Biswas さんによる
I can not access my phone speaker
What should I do?????????
Akash Bangle さんによる
Suara speaker pecah dan tak karuan
Mukbir Panglima さんによる
Kalo hp tak sambung kabel charger mati hidupkalo sambung hidup normal padahal baterai 89%mohon petunjuk
