メインコンテンツにスキップ
Repair and disassembly guides for the Compaq Presario CQ60.
28回答 すべてを表示
Laptop turns on but screen is black.
I'm currently having same issue. Here's what I noticed, the screen turn on but emitting a very low light, I can see it.
However, I haven't gotten a chance to take it to a laptop engineer, here's what I do to my laptop each time I power on or reboot
I loosed a part of my compaq presario CQ61 where the port that connects the screen with the motherboard is located, because anytime I power on or reboot the system, the issue occurs, but disconnecting the port and connecting it back brings the full light of the screen.
Also, shutting down the system, and leaving the port still connected, I notice a white flicker on the screen, time by time, despite the system is off, this makes me think it's a motherboard issue.
I've tried all possible things according to what I've learnt from a friend about reparing laptops, that's to say I can disassemble a laptop and assemble it back, and can also tell some cause of a faulty laptop.
Please I'm still looking for a solution to the problem, I've described the problem in detail. A laptop engineer might charge even more than the problem of the laptop.
I've also tried cleaning the ram, I have two rams, and I've tried a single ram on different ram slot, after cleaning the ram and the slot (maybe the cleaning I did wasn't enough :))
My thought now is that probably the two ram are already corrupted. If not, should be the cpu paste.
Because it's been over three weeks I closed my laptop lid, I usually leave the lid up, unless I have to carry/package the laptop into a bag when I need to carry the laptop around.
Please I'll be glad if someone can point out which direction I should follow. Thanks
Edit:
The issue was later resolved, I don't know how ot happened. Just after trying everything with no solution. I power on the system to use it my usual way, (disconnecting the connection between the motherboard and screen), but to my surprise it worked.
But that's not all. Yesterday the system was unable to power on, though the screen still flicker while the system is off. I guessed it's a motherboard issue. Then I took it to a laptop engineer, and he said same. Too bad I'll have to face it 😩
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
good morning,
That's quite the unfortunate event. May i ask, is this a work device or a personal device?
Next thing, Finding parts for this laptop with a quick google search is relatively easy, despite it's age.
However, having said that, if this laptop isn't worth that much it may be best instead to convert it to a desktop at home machine. Then buy a used modern one. This thing did come out in 1993 and if your still daily-driving it, it might be time for an upgrade. It might be sentimental to you, in which case keep it as a relic or one day try and repair it.
Screens for these laptops are about 50 AUD where i live, so it wouldn't be too much to ask if you need this up and running asap.
Let me know if there's anything else.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It's a personal device. However, I'm not sure it has something to do with the screen, because I just replaced the screen few months ago. Yeah that was around late April
さんによる
コメントを追加
Based on your description, there is a shorting cap on display controller, on the back of the display.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I don't fully understand what you mean here, but I guess you mean it's a screen fault. The screen was replaced few months ago, and even now, the system does not power on, it should be a motherboard failure
さんによる
コメントを追加
回答を追加する
Junior Ohanyere さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 16
今までの合計 82
