メインコンテンツにスキップ
2016年3月に発売されたSamsungの機種です。モデル番号はSM-G930Vです。
20回答 すべてを表示
Why can't I open the back panel after heat
So I'm trying to replace my battery on a samsung galaxy s7 and the back panel still won't come off even after blisteringly hot heat from a hairdryer. Is there any way I can use something other than heat to help get the adhesive off?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
@esaiboatrig2973 are you referring to the back glass? Has it ever been disassembled before? Any change in adhesive?
さんによる
@oldturkey03 Yes I am reffering to that. It's never been dissassembled.
さんによる
コメントを追加
2件の回答
You will need a tool to remove the back working round the edges the glue that holds it is all round the edges and in the middle and if you have not done this before it will probably break it a repleacement in cheap
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
@esaiboatrig2973 you need the back to be at about 140 deg F for the adhesive to soften. I would suggest either a heat gun and a good thermometer, or a hot plate to accomplish this. The heat has to be consistent and even. cover your camera while you heat it. use something like this tool iSesamo Opening Tool|Shopping|MiscTools}&pk_source=google&pk_medium=cpc&pk_kwd=&gclid=Cj0KCQjwiIOmBhDjARIsAP6YhSX_AFLzLeDUcSLLQHJm75sCh4BrDZLdEUAlUFBvy7XLJh-yBF9631UaApEwEALw_wcB and leep reapplying the heat. Yes, do wear some gloves since it will be unpleasant to hold your phone while doing this.
Springy steel blade features a smart tip design and a handle with a great no-slip grip. Effortlessly pops open iPod, iPad, iPhone and many other tablets, smartphones, and devices.の画像
製品
$9.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Esai Boatright (topdogman) さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 7
過去 30 日: 9
今までの合計 82
