メインコンテンツにスキップ
2021年10月発売。モデルナンバー GB7N6(非5G mmWave)、G9S9B(5G mmWave)。
50回答 すべてを表示
All sensors failed after replacing display
This is after my second display replacement. First the audio was muting frequently for a second. It even happened for bluetooth. Then I noticed the proximity sensor failure and then gyroscope and rest. I have even removed and reinstalled the display. Did I miss any connection or my sensors were damaged somehow during the replacement? Pls help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
@mmhebron Hello! A little bit of a long shot, but have you tried factory resetting the phone? Sometimes replacing parts can cause very weird software issues which is what this is sounding like, it's likely to either be that or some form of motherboard damage.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
Yes, I forgot to mention that. I did reset and nothing has changed. After that I have removed the screen and installed again.
さんによる
@mmhebron Ah, unfortunately then the most i can suggest is ensuring that all other connectors are properly seated and that none of the antennas are damaged or deformed!
さんによる
Last night I have installed security update 5th August 2023 and everything is working fine. Phone resetting failed, but a 22mb security update fixed it. Wow Google, are you for real? 😒
さんによる
@mmhebron Sounds like most tech companies to be honest.... glad it's sorted atleast!
さんによる
コメントを追加
I have been facing the exactly the same issue since yesterday. Hope next security update will fix this. Fingers crossed.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Moshe Hebron manukonda さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 23
今までの合計 139
