How to change charger pin
How to change realme 8i charger pin full details
この質問は役に立ちましたか?
This may just be an artifact of auto translation, but I'm going on the assumption that you are asking how to change the USB-C charging port on your phone.
Sorry to say that iFixit doesn't have a guide for replacing that on your phone, but there's a Spanish site called Nadie Me Llama Gallina, or Nobody Calls Me Chicken, that does have just what you need. If you view it with the Chrome browser and allow it to do the translation, the guide is very much usable.
You're fortunate in that your USB-C port is mounted on a small auxiliary board mounted near the bottom of the phone and can be replaced by itself fairly easily. Here's the guide you need.
Manuals / Realme Narzo 50 (Realme 8i) / Auxiliary plate
You shouldn't have too much trouble locating a replacement part; I usually check sites like AliExpress, Amazon and eBay among others. Here's one of the first ones I found on a cursory search.
For Realme 8i Original Charging Port Board – Alexnld.com
Good luck with your repair; let us know if you need any help and be sure to tell us how it turns out for you!
このアンサーは役に立ちましたか?
How to change charging jack
Did you bother to read the previous responses where that question was already answered? Please go do so before contributing nothing to the discussion.
Jack change.realme 8i
Please RTFM.
If you have a similar phone that is no longer in use you can take it apart and use that particular part for the other phone .
過去 24時間: 0
過去 7 日: 5
過去 30 日: 35
今までの合計 4,116
4 件のコメント
Display change
Radmi 8 さんによる 共有
If you are looking for a display change, @dadibrokeit already gave you a great website to fix your phone. Here is the link for the display change incase you are unable to find it: https://www.nadiemellamagallina.com/en/m...
Robust さんによる 共有
it's very simple if you have the right tools
gsburrows33 さんによる 共有
Charge nahe hota h
Vikash Barar さんによる 共有
