Is there a way to fix a broken rear tire, part number - 330072007?
The inner part of one of my Ryobi lawn mower's rear tires is cracked. Replacement isn't possible until 09/14/23. Is there a way to fix the tire?
This vendor (example only, if Ryobi does not have) appears to have the replacement wheel in stock: https://www.partswarehouse.com/Homelite-...
Could you share a picture of the cracked wheel? iFixitでの質問に画像を追加する方法 That may help with repair ideas; a plastic wheel may be difficult to repair adequately for this application).
I looked to see if anyone has made a 3D print available of this wheel and didn't find one (my idea being that you could get a service to print you a new plastic wheel--like this fix BCG800XL Grinder Jamming due to Worn Impeller -- that might last at least a while (but probably not be cost effective or durable enough in this application as a long term fix).
ガイド
難易度:
とても簡単
2 - 5 minutes
ガイド
難易度:
中レベル
10 - 35 minutes
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 8
過去 30 日: 23
今までの合計 191
