メインコンテンツにスキップ
HP EliteBook 840 G6, HP EliteBookシリーズのHPノートパソコンの修理とトラブルシューティング情報です。 2019年5月にリリースされました。
19回答 すべてを表示
Laptop power blinks white and orange, not turning on.
I have a new laptop, worked fine and then it was dropped. And now it no longer turns on. The power button would light up along with the caps lock light then turn off. I plugged in the charger and it shows no life. So i took the battery out and put the power adapter in and now the indicator light blinks white, amber, and then stays amber. Sometimes the keyboard lights will come on and sometimes it will not but the screen will never come on. Might I mention that while putting the battery connector back in, a light on the board would flash white and go away. Same with the power adapter. I'm not sure what to make of it, I contacted HP Support and they were no help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント:
Check and count how many times the caps lock blink?
Then I will show you the error table.
さんによる
Just once. It comes on for a few seconds then goes off.
さんによる
コメントを追加
1 件の回答
Hello @greykingdom
How many times does the caps lock light flash? I know that if it flashes three times, it is most likely that the RAM is not seated correctly. Just find the ram, remove it by pushing the metal clips away from the sides of the RAM, and it should pop out. Put the RAM back in, and the laptop may be functional.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Grey Kingdom さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 18
過去 30 日: 54
今までの合計 1,975
