メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年10月26日にリリースされた第4世代のSurface Proタブレット。
Screen replacement of Surface Pro 4 with a Surface Pro 5 screen
Receive surface 5 screen, received cable x00341z2yr to attach new screen to pro 4. I transferred the Surface 4 digitizer board to the new screen. Machine turns on ok and screen comes on fine. I still do not have screen touch or use of pen. I have ordered a new digitizer board and will try it for correction of touch screen. Other suggestions for repair of problem would be appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
So, just to clarify, you’re replacing the screen of your Surface Pro 4 with a Surface Pro 5 screen?
さんによる
Yes, I have a surface Pro 4 that the screen touch is not functional. In the past I have also attempted to fix the flickering problem with some success. I decided if screen touch caused replacement to be needed I would use the Pro 5 screen as suggested by other blogs.
さんによる
コメントを追加
2件の回答
最も参考になった回答
I had the same problem after replacing the battery on my surface pro 4 tablet and destroying the original touchscreen, which was almost impossible to dismantle.
After an initial negative experience with the surface pro 4 replacement screen from ifixit (fortunately reimbursed), which caused the well-known flickering problem, I finally managed to replace it with a surface pro 5 screen, which is compatible.
I couldn't find it at ifixit but it's easily available on the big online shop ;o) ATTENTION: make sure that the latter is supplied with the adapter cable for the surface pro 4.
After that, I also encountered the problem of the non-functional touch screen. I'd taken the NTrig module from my old screen and stuck it back on with standard double-sided adhesive tape. But the touch function worked in a totally random way, if at all. After a lot of searching and trial and error, I found some information about grounding this famous NTrig module. To do this, you need to use a special adhesive that ensures electrical conductivity. But here again, I'm not sure I have the right explanation, so after several attempts, I finally found the solution that worked for me. It seems that the conductive adhesive should only be placed in a specific area (see the red circle in my attached photo), the yellow part is the standard double-sided adhesive.
In addition, you need to make sure that the standard adhesive isn't too thick, preventing the other from adhering properly and ensuring that the NTrig module is earthed.
Lastly, I also had to uninstall and let windows update reinstall the touchscreen module driver.
I hope this helps.
Translated with www.DeepL.com/Translator (free version).
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
Are you able to share the electrical adhesive type , brand and where to purchase ? Once I have the conductive adhesive , i will apply this repair process. Thank you for your insight and sharing !!
さんによる
@davem52722
Brand: Laird
Ref: DT03B Double Sides Conductive Tape
I bought it from Mouser Electronics.
Here is the link for where I live (France):
https://www.mouser.fr/ProductDetail/739-...
And here, the link of manufacturer:
https://www.laird.com/products/enclosure...
So, I know it's a bit expensive to buy 20 metres of a product that you'll only use a few centimetres of, but I wanted to be sure I was getting a professional product given all the problems I'd had with the countless assemblies and disassemblies of this wretched computer.
The main thing is that it works now.
I hope it works for you too.
さんによる
Thank You Very Much!!
さんによる
@davem52722 you're welcome.
Please let me know how it turns out, it'll be another piece of feedback.
さんによる
Hi Dave! Did Phil68 solution worked for you?
さんによる
1以上のコメントを表示
コメントを追加
Copy paste from another thread to try and help spread the word and help the next person (Touch screen won't work after screen replacment)
I had the same issue. After damaging the screen while replacing the battery on my SP5 I bought a new screen. The screen worked fine but the touch interface didn't work at all. Since the EOL of Win 10 I've been running Linux so I couldn't check device manager for problems. As a test I installed Win 10 on a USB by using Rufus. Once that booted up and all drivers were installed, the touch screen partially worked but had dead spots. I finally struck gold and found an old Reddit post. The solution is to run a calibration utility called "CalibG4.exe". The touch screen now works in the BIOS, Windows, and Linux. The original download links no longer seem to work but I did get a copy from another file sharing service. Take a look at the following links:
https://thedigitallifestyle.com/w/2018/0...
https://www.reddit.com/r/Surface/comment...
https://search.brave.com/search?q=491758...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dave M さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 42
今までの合計 1,580
