メインコンテンツにスキップ
https://www.westerndigital.com/en-in/products/portable-drives/wd-my-passport-usb-3-0-hdd#WDBPKJ0040BBL-WESN.
2回答 すべてを表示
Clicking Sound 16 Times Then HDD Stops Spinning | Not Detected at all
IssueMy 4TB WD Passport Drive fell from the desk and since then makes clicking noise.
Video of the issuehttps://drive.google.com/file/d/1cfWMObC...
Video of Clickinghttps://www.youtube.com/watch?v=VHjnaW3p...
I opened the HDD in a clean environment & closed the casing within 2 minutes. I wanted to do this to verify if the platter had broken or not. Or, if the heads were stuck on the platter or not. Both not being the case. It seems to be in the right position but keeps trying to read and fail. Ultimately the HDD stops rotating. The light of the HDD is ON throughout the process though.
One more thing worth noticing is, as soon as I connect it, while it clicks and rotates for a few seconds (before stopping), I do see it appear here in Device Manager (but not in Disk Management).
The clicking noise comes for 16 times as if some algorithm has instructed it to do so as a fail safe mechanism. Then the rotation of the disk stops. Any thoughts???
Note: Data Recovery Guys are asking ~1,250 USD for the recovery. :(
Regards,
Shashank Sinha | New Delhi India
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
While I understand you did open the drive in a clean environment, some are sealed with helium inside because it's less dense. Depending on how important your data is, I would highly recommend you leave it to a professional. The drive needs repairing. The more you attempt to repair and tamper with it yourself, the worse it's going to get.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Shashank Sinha さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 37
今までの合計 236
