My wifi not showing any name and not connecting to any wifi
I try searching wifi but not showing a single wifi name it will not showing wifi mac address in about
Hello
You should check if your router is connected to the internet. You can do this by opening other devices in your home that are also connected to your router. If the device doesn't connect to the internet, then the problem is most likely with your router and not with your TV, if your other devices are having no connection issues, then the problem is most likely with your TV
Since the connection between the router and your TV is fine, you should try resetting the network on your TV.
Once your network has been reset, select Network Settings to set up your connection again.
If you are still having problems, a factory reset may be required. Keep in mind that this is different from resetting your network.
After performing a factory reset, you will need to start the initial setup process for the TV and reconnect the TV to the internet.
このアンサーは役に立ちましたか?
I call it service then they asking it will be driver fault
過去 24時間: 1
過去 7 日: 7
過去 30 日: 8
今までの合計 45
