Stuck at screen logo
Stuck at logo problem
Hi @fake72773,
Try starting the phone in safe mode and check if it starts OK.
If it does than a downloaded app may be the cause of the problem. The trick is to find out which one.
You will need to uninstall each downloaded app one by one, and then start the phone in "normal" mode between each uninstall to see if it starts OK.
When it does the last downloaded app that was uninstalled was the problem. A downloaded app is one that you downloaded and installed and didn't come pre-installed with the phone.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 9
今までの合計 457
